...that the Sears 3-point hitch could be hazardous to your health?
I went to my neighbor's to borrow his York rake with the Hydro-Trac. Rather than hooking it to the hitch plate, I used the drawbar on the 3-point. As I was hooking it up, the hitch dropped from the lifted position to the lowered with the full weight of the rake on it, causing the handle to swing backwards at a high rate of speed - until it hit me right on the noggin, anyway.
I think I slowed it down significantly.
Do these things usually lock in in the raised position? I think it was the jostling I was doing, trying to get the tongue of the rake to line up with the hole in the drawbar so I could drop the hitch pin through that did it. I would guess that driving over rough ground could do the same thing, though.
My head hurts...
My head hurts...
