I thinking of adding a whole house humidifier to cut down on the dust and hopefully improve overall inside air quality. The Mrs' allegies are such that we are either running the AC or heat so the heatpump removes alot of humidity from the air.
I'm looking for ideas suggestions.
I would think adding the water in the conditioned feed duct would be better than adding it to the return as it seems the HP would remove alot of the just added water. I could be wrong, thats why I'm asking
I've seen nice models with a way mounted humidistat near the thermostat where one can set the amount of humidity.
My ducts (both feed and return) are flex duct where they connect to the inside unit and I think that would definitely effect the type of humidifier to use.
Also, I would think that I'd want it to run all yr long, in AC & heat.
I have a dual fuel heatpump that uses natural gas as the aux heat.
Suggestions?
Dave
Suggestions?
Dave
