Hi All,
I have a White Outdoor LT524G tractor that I am suddenly having issues with. I went to mow the lawn yesterday, and could not get the tractor to stay running for more than 4 - 5 seconds before it would die. The battery needed charging, so I went and trickle charged it overnight. I went to start the tractor again this evening, and it started a lot more easily, but still would not run for more than a few seconds.
When it starts, it sounds normal, but then dies like something is grounding out the engine (very similar to what happens if I shift into reverse while the blades are engaged). I am guessing I should look at the safety interlocks and see if there is one that is malfunctioning, but am wondering if anyone out there has more insight - or perhaps can point me in a more likely direction towards the source of my problem.
Here are the specs:
Tractor model #: 13A2771G790 (March 2006 mgf date)
Engine model #: OV490EA (Tecumseh) -- It's an 18 hp engine.
Thanks for any help you can provide.
Here are the specs:
