1 - 2 of 2 Posts
Hi everyone several times while mowing my pto clutch disengages. I can hold the switch up and it will keep running. Any ideas. I have looked at the wiring diagrams and there looks to be a few items that may cause it. Any help would be appreciated
If holding the switch makes it keep running, my first thought would be a bad switch. Can you test the switch? If they're inexpensive, replacing that would be a reasonable place to start.
Alternately, if you have contact cleaner spray, you could try spraying that inside the switch, and working it back and forth a bunch of times, to see if you can help the internals make better connections.
Or, if I misunderstood the switch behavior, how does the tractor behave if you stand up from the seat while the PTO is engaged? If the engine stays running, but the PTO shuts off, then maybe you have a bad seat safety switch, or an intermittent connection to that switch.
1 - 2 of 2 Posts
