If you look at the Johnny Bucket Jr. you won't look at the Sears bucket again!
Just saying, I thought the Sears bucket was a contraption, the JBJr looks better engineered, heavier duty, more options etc etc etc.
I have the Sears/Agrifab box blade. It is great as a counterweight for the JBJr and does fine moving fresh,loose material. It is even fine for an occasional, reverse snowblade. But when you get into any established ground, it quickly becomes useless.If you only have the $500 to spend and you want to do some grading, I'd recommend a sleave hitch and a box scraper. I haven't used a box scraper, but since it's a grader blade with removeable side plates and a scarifier bar I'm guessing it would be even more useful. http://www.sears.com/shc/s/p_10153_...r+Attachments&sName=Rollers,+Rakes+&+Levelers
I agree with NoTime - I own the Brinley and have seen the Agrifab - Brinley is better built for sure IMO.I have the Sears/Agrifab box blade. It is great as a counterweight for the JBJr and does fine moving fresh,loose material. It is even fine for an occasional, reverse snowblade. But when you get into any established ground, it quickly becomes useless.
A number of users have said that the Brinley box blade (available to order from Home Depot and others) is better built and designed, and based on my agrifab experience, I'd believe it.
