from what ive heard the most popular alternator to use is a gm 1 wire or 3 wire alternator
my 12 volt conversion has the 3 wire GM.. seems to be goodThe GM 3 wire is the one you want, 12SI, the 1 wire has to be rev'd up before it will start to charge.
Yer amp gauge will work just fine, unless it is broke or you just want to change it. As for the removing the neg post, yeah it will still work but that is not really a good thing to do to the internal reg of the alternator. Just use a volt/ohm meter and measure the voltage at the battery with the engine running it should be between 13-14 volts.
The "take the negative cable off" thing WILL NOT!!!!! Work.The GM 3 wire is the one you want, 12SI, the 1 wire has to be rev'd up before it will start to charge.
It depends on how low the battery is. The ammeter should work with an alternator the same as a REGULATED generator, that is, you start the engine, it shows "some charge" which should gradually taper to center as you charge up the battery.u:
An ampmeter on a 12v system would only show very little charge if its working, am I right on this?
I get lucky one every year or two :sidelaughAin't it nice when it is something simple...
