Where's the hydrostatic drain plug on a toro 212-h. i cant find it. do i have to pump it all out or????? also what kind of oil should i use in it? thanks-Brandon
Can you post pictures of the transaxle and pump? Does the pump unbolt from the axle? If so they each have their own separate fluids. I had a 252-H which had a separate pump and axle.
There might not be one. My 210-H manual doesn't even say anything about changing the hydro oil. Just check the level. 5W-20 oil if memory serves me right.
What is the long model number of your tractor? I see some service bulletins on the transmissions for some of the 212-H's and believe Toro has a transmission manual posted.
Garry
