1 - 6 of 6 Posts
9K+ Poster
Deere rates it at 1360# at max height at the pivot pin (the pivot where the bucket attaches. It also rates it at 1700# at 59" lift height. The 300X has about 3-400# less lift capacity than the 300CX. :)
Just passing through
But your tires will be your weak point...;)
Tire Loads
NOTE: Maximum load capacity for single tire.
Front (7.00-14 6PR R1 GA) 430 kg (948 lb)
Front (27x8.50-15 6PR R3 GA) 750 kg (1654 lb)
Front (27x8.50-15 6PR R4 GA) 750 kg (1654 lb)
Front (25x8.50-14 6PR R4 GA) 620 kg (1367 lb)
Front (25/10.50LL-15 6PR GOLF GA) 700 kg (1543 lb)
Rear (11.2-24 6PR R1 GA) 990 kg (2183 lb)
Rear (41x14.00-20 4PR R3 GA) 1490 kg (3285 lb)
Rear (43x16.00-20 4PR R4 GA) 1420 kg (3131 lb)
Rear (15.00-19.5 6PR R4 GA) 1790 kg (3946 lb)
Rear (41LLx18-16.1 6PR Golf GA) 1990 kg (4387 lb)
So with R4's about 1400 Pounds give or take?
No...NOTE: Maximum load capacity for single tire.
Front (27x8.50-15 6PR R4 GA) 750 kg (1654 lb)*2= a maximum of 3308lbs supported by two front tires, which would include the FEL, front axle, and a percentage of the engine...then you have your load...and the higher the FEL is raised the more of the load that is transferred off the front axle and on to the rear axle
1 - 6 of 6 Posts
