1 - 8 of 8 Posts
I just bought a 3000lb HF winch and would like to mount it to raise & lower the sleeve hitch. I have a MTD 840 garden tractor and would like to mount it on my back fender. I'll be attaching a modified to sleeve hitch light weight 3pt forks. I want to carry 160lbs of weights and / or a utility box down low to give more traction when I need it. Should the back fender be strong enough for the winch mount?
Harris
you didn't say what kind of tractor, but the answer in my opinion is no! But post a picture of your fender.:thThumbsU
If mounting it on the fender is not a good idea, can anyone give me an idea of where to mount it. I have a MTD 840 gt.
Harris
behind the seat on the main frame, don't know if there is room, but a picture would help.:fing32:
Sorry, maybe you have a one piece pan that has both fenders and the seat on it all in one. In that case I don't have a clue? I would still want to mount it some how to the frame. :sorry1:
My Orange Jane Deere
:wwp: that would help so much. :thThumbsU
Without pictures, it is a guess, but I'd say no, a fender is not a good place to support 160#.
Now, if you made a little steel frame that mounted to the same place your seat mounts do, you could carry that load on whatever holds your butt up.
Harris
Initially, I mounted my winch at the top of sleeve hitch mounting plate. I have since added another 8" so I could mount it higher. This is where you would need to mount your winch.
1 - 8 of 8 Posts
