1 - 20 of 29 Posts
seeing as no snow so far, I thought I would try to install the blower impeller rubber add-on/modification. (as I cannot think of anything else it needs... even waxed it twice while waiting on snow...)
While not a deere, this guy had great results (before and after vid too!)
http://www.youtube.com/watch?v=IMbjut8c4MU
But I cannot find the rubber?? An old tire sidewall might work, but I cannot think of where to get corded 3/8" thick rubber??
My local TSC only had 3/4" thick horse mat, or some thinner stuff, but the thinner stuff was not corded but rather some type of compressed recycled rubber, it just flies apart from the rotation CF.
:thanku:for any direction!
MXZRXP, I put an impeller kit on an old walk behind unit and it works great! It really improves the overall performance of the snowblower. What unit do you plan to install the kit on? I have to say I was a little disapointed when they delivered my brand new model 47 and I saw it had a plastic impeller. I hope it holds up. You cant installal an impeller kit on a plastic impeller.
A PLASTIC impeller on a new genuine JD snowblower attachment? That tears it, it would de-attach me from any new JD equipment for good and I'm considering buying a new JD model next Spring. I just can't go there! Some moving parts are just... "sacred"!
Sometimes I wonder just how much "savings" a company thinks they're getting when they are losing entire equipment sales. Do they think there's enough uneducated/uncaring buyers that don't know what's going on that they can buzz this kind of thing past 'em while the check clears? Or will this give JD such a bad rap down the road from failures that they won't have saved the shareholders even so much as a nickel? I guess time will tell, but I know what I'll be looking straight at for my next model.
Hello
Make your own.
Just go to a local Fleet and Farm store or Tractor Supply and buy a piece of baler belt. I just bought a 1 foot piece from my local Fleet and Farm Store and it cost me $5.00 and some change.
Good Luck and Regards
Buckatabon
Discussion Starter · #10 ·
I bought a foot of baler belting from TSC http://www.tractorsupply.com/replacement-baler-belting-4-in-wide-2-ply-210-nylon-ft--1420009
I used the same material on my single stage tractor snow thrower and my MTD walk behind snow blower.
Here is the install thread... http://www.mytractorforum.com/showthread.php?t=170564
that's the do-it-yourself way with the TSC material, but the dolt of a salesKID I had said they don't sell it! I'll have to go back as the website says available in my store!!
I am trying it on the SS 42" er. I have been very pleased with its performance but the difference it made in the video sure seems worth the 1/2 hour it will take to install. When really sloppy I turn off the PTO and use the blower as a plow, looks like this guys would throw water :)
close enuff works for me
I used a peice of rubber off a toro single stage blower that I scrapped. Works very well,,you can buy a replacement rubber wiper from toro, they do wear out after a few years.....If you can get in and out of the RED store without being seen.:D
MXZRXP,
How are you planning on using this on a single stage? I'd love to see some pictures and a before and after like the guy in the video.
Would also be interesting to see if it throws further at a slower speed. I know when I had my snow blower last year I had to move as fast as possible to really throw it.
Keep us updated!
The issue isn't driven by cost in that the plastic impellers are less expensive, thus losing business on new equipment sales. The issue is that consumers are idiots and the plastic impeller is there to protect them.
You should see the crap that people pick up in their snow blowers. And there is *ZERO* forgiveness in a steel impeller. The consumer already figured out that if he used grade 8 bolts as sheet pins, it'd work a lot better and not sheer the pins as designed when they pick up a wooden stake, rocks, branches, newspaper, kids toys, etc. I was amazed to see my neighbor down the way stake his driveway in rebar. Yes. #4 Rebar. So you throw it in a steel impeller, and you destroy the entire snowblower, break chains, gearboxes, shafts, etc.
While you and I know better than that, most don't.
They use plastic impellers on the Model 44 aswell. Stladrill put the Model 47 impeller in his Model 44 blower with some mods. I am waiting to see how it works out and his reviews on what he done.
"The issue is that consumers are idiots and the plastic impeller is there to protect them."
It is not my place to absorb deliberate design defeciencies to please JD bean counters or government bureaucrats. For me it's steel... and I'll eat the ½ hour of digging out a frozen Sunday paper. At least I won't have to toddle to the dealer to replace the impeller when I buy the new copy of the paper. Some things are just going dumber...
Another example: JD miracle plastic foot/fender deck on SCUT's. Should one get into a situation such as "too close to a tree" while operating. Plastic deck is G-O-N-E, metal deck is B-E-N-T. Though humiliated by my unsafe operation, I can unbend my steel fender... I can't "un-crack" my shattered plastic fender. It's automatically a new hi-buck dealer replacement which is not in stock for who knows how long.
This example points to JD's self generating replacement sales AND cheap OEM costs over lasting repairable materials. It will continue in all markets as long as buyers will stand for it. So it looks like the "1000 series" are the beginning of JD's descent into the "throw away" market (only to me possibly).
I'll bet Berco won't be considering any plastic impellers on their own branded blowers.:D
In Herman (my X748) ate the paper (no pics today) my X748's snow blower's plastic impeller survived a buried newspaper mine and lived to blow another day (season).
Getting ready for year #2 with it and the original shear bolts (realizing I just jinx'd myself:banghead3)...:thThumbsU
Clarences Kit is a must for clearing the
melted snow from the bottom of the
impeller drum.
The Pre-drilled galvanised mounting plates
take all the guess work out of drilling into
the impeller paddles and assuring that the
impeller drum is swept clean at every revolution
of the impeller.
ABOUT THOSE CHEESY Plastic John Deere Impellers;
I wil be using my 42 inch 2 stage this winter on my LA115
for the first time and I will report back quickly when
the time comes. I am not crazy about the design for sure.
The bad thing is I cannot use one of Clarences impeller kits!!!!!!!!!!!!!!!!!!! :praying:
Then vote with your consumer dollars and buy a different tractor. I'm sure you and your Berco will be quite happy. Until the do something you don't agree with.
I am always amazed at the look I get when I tell new snowblower owners to make sure they walk the area before the storm so they don't pick up rocks or other debris in the blower.
If you feel better ******* and whining about bean counters go for it. I don't have the plastic break in a whole lot of pieces. Most of the time it cracks and gives way. I take a piece of aluminum and a few pop rivets and off I go. A little extra effort for me and JD stays in business by being competitive with others. Worse comes to worse they sell plastic weld kits that use flame and plastic rod. Makes it about the same as playing with metal if you want to.
1 - 20 of 29 Posts
