where is the old going
893 Views 1 Reply 2 Participants Last post by  RestMyCase
I have a 1982 (I think) 446 case.
it run ok and mows ok. but it uses some oil,
If I pull it hard and mow most of my big yard is will lower the oil about 1/2 the marks on the dip stick, which is not too bad. But I always check it before and after I mow.
because after a couple of mowing without adding oil, it would be out of oil
I do not see any oil smoke while mowing. have seen some smoke at startup.
a few times.
I use shell rotella 30 weight oil
any ideas, should I change the type oil I am using??????????
1 - 2 of 2 Posts
Check & clean the crankcase breather assembly ...
:fing32:
1 - 2 of 2 Posts
