1 - 13 of 13 Posts
Depending on the model, Case/IH probably still has them. And sometimes they are really close, and strange sometimes, less than aftermarket parts.
What model is your tractor..?? You can go to Messicks, and use the online parts feature at the top left of the page in the menu. Place your cursor on the "Online Parts", then select Case/IH when it appears. Enter you model number in the block, then select your model out of the list that appears next. Then select the component they would be in,and click on it. An exploded view of selected component, list of parts by description, and price of part will appear.
If you want to compare OEM prices against aftermarket parts, copy and paste the part number to a search engine, such as Google, and you should get a ton of hits.
I also have a 240 Utility, with Fast Hitch. Would you be meaning the clamp for the rail that controls the depth, of attachment, or level of the drawbar, on the Fast Hitch..??
Maybe yours has 3 pt. hitch, although I've never seen one.
If that is the clamp you are referring to, I looked on the Case/IH online parts store, and they don't show a part number for it. But, if a used one would work for you, here is a list of 15, 240's in salvage yards that may still have a decent one on. INTERNATIONAL 240 Parts, INTERNATIONAL 240 Machine Salvage, INTERNATIONAL 240 Dismantled Machines At TractorHouse.com It only takes a phone call to check.
If you mean the knob that goes on the single lever, then Case/IH still has them. Part number is 371602R1. The price is $5.80.
You can also copy and paste that part number to a search engine such as Google. I did, and in this case, the Case/IH part is less. Aftermarket one's ran from $6.95, to $8.45.
Might help if you cold post an actual picture. My 240 has Fast Hitch, and just an adjustable position stop for the lever, and there is only 1. And as mentioned above, Case/IH does not show that position stop on the parts page, as an available part. But, you may get a used one off one of the salvaged tractors in the list, of the link I posted.
Not quite the same. And I think the guide side straps are a bit wider on the 240. It probably wouldn't be hard to make one, if you'd find the right sized knurled thumb screw.
I can take a few pics of the one on mine, to give you an idea.
1 - 13 of 13 Posts
