I need to rebuild my deck and I'm trying to find the model number on the deck. It's a 36" rear discharge from a 72' Raider 10. I imagine that I'll have to cut the spindles off since I was unsuccessful trying to remove the pulleys last time I tried. I'd really like to know if part #103119 is the correct spindle assembly since it seems to be readily available. Any input you have will be much appreciated. Thanks in advance.
Daren
Oldbie
Wow......if those spindles are still good.....don't cut them off.....they are
too expensive to replace. Take it to a machine shop (or similar) and have
someone with lots of tools and ideas take them off for you.
The numbered tag should be very visable on your deck. I believe it is
on top near the rear of the deck. Silver lettering on a black background. But.....the deck could be a different era than the tractor
as most all these are interchangeable.
You can replace the bearings in it if that is all that is wrong.
Thanks for your responses, fellas. I pulled it all apart tonight (pulleys came right off after soaking in PB blaster). The replacement bearings (integrated spindle shaft) are fortunately part #103119 so I ordered 3 new ones. Cheaper fix than I thought it might be and I'm glad because I love mowing with my Horse.
Good!
