1 - 3 of 3 Posts
what's best thing to knock roll pins out to take wheels off, and what's the best thing to loosen it up with? wd-40?
I Love All Color Tractors
I would use PB Blaster penetrating oil. Soak the pins with this several times allowing plenty of soak time between applications. Also, soak the area where the axle and hub meet with PB at the same time as you soak the pins.
I would then use a pin punch, the same diameter as the pins, to drive them out.
1 - 3 of 3 Posts
