1 - 7 of 7 Posts
i have a c120 automatic that is having some hydro issues and wondering if someone else has ever ran into the same thing. when i first start it it wont move but if i leave it in the forward position it jerks and moves fine then if i move the hydro full forward it will go for a few seconds then stop and then it will act like its picking up oil and starts to move again. any help is appreciated.
By chance have you changed the tranny filter?
yep ive changed the filter and the oil level is fine. the release valve is also closed. it works fine once you get it moving if you dont go into full forward or reverse position.
All the Hydro problems on here & I'm not sure if I've ever seen anyone post about the screen in the rearend maybe needing cleaned . From what I seen when I tore one down just to see how things work I found that they have a screen in the rearend that it sucks the fluid through then runs it through the system & only through the filter on its way back into the rearend . You'all can do what you want but I'd check that screen.
1 - 7 of 7 Posts
