So after playing around with the Craftsman GT II: http://www.mytractorforum.com/14-craftsman-sears-forum/891393-craftsman-ii-gt-loader.html
it's been doing very well, I think the only thing it could use in terms of power is more traction. I put chains on the tires which did improve it somewhat, although on inclines, especially in gravel or soft dirt (which is the case nearly everywhere on my property) it does spin a little bit. I was looking around YouTube about filling tires with windshield washer fluid/antifreeze to add weight and traction, wheel weights are available @ about $1/lb (50lbs can be added to each side out of Sears catalog). No more weight can be added to the weight box, it really needs to be in, or on, the rear wheels. How much fluid will a 23x10.5 - 12 hold? What is the easiest method to do this? I would guess it would take a tube to fill the tires with a fluid, I'm not sure the tires have tubes, any advice on adding tubes? could tubeless tires be filled with something solid for traction and weight? thanks for any help that can be offered
