23x10.50-12 Tires with BM17976 Weight
BM17976 is a 23 kg (50 lb) plastic coated weight and includes the necessary hardware.
· Install weight as shown.
M71770
· Measurement (A) should be 160 mm (6.3 in.).
26x12.00-12 Tires with BM17973 Weight and BM17972 Weight
BM17973 is a 33 kg (72 lb) Weight.
BM17972 is a 23 kg (50 lb) Weight.
You must also order BM17977 attaching hardware when using one BM17973 and one BM17972 weight. Order BM18101 attaching hardware when using one BM17973 and two BM17972 weights.
· Install weight(s) as shown:
M71770
A - One BM17973 and One BM17972 Weight
B - One BM17973 and Two BM17972 Weights
· Measurement (C) should be 200 mm (7.9 in.).
· Measurement (D) should be 260 mm (10.2 in.).
