What is the most common problem that causes a sloppy wheel on the right side on a tube frame. Have not disassembled yet but looking at the parts breakdown it appears to be between the hub and wheel hub?
What model tube frame? some seem to have bushings and some don't.
Jason
EDIT: I just saw your other post where you said you have a 750:banghead3 I am checking the manual for that now.
My 900 had lots of wear in between the drive collar and freewheeling hub. I have a feeling that your 750 has the same issue.
on my 1050 .the po let the wheel hub run bad so long it wore the main rear houseing out, had to replace the hole thing .lucky I had a couple sitting around.insanity rules.mine was on oposite side.on the locking side.:banghead3
