It is getting to that time of year from what I read to start thinking of prepping the garden for winter. When we stated the garden in late spring this year I told the wife to go small as we just moved into this house. So we did a 10’x20’ in an area that had not been farmed in over 10 years or more. At the time I only had a 12” yes that is right 12” Toro 2 stroke tiller to break ground for planting, took 2 days never again. The wife wants to go bigger in the garden. She said 20’x20’ but I am thinking 20’x50’ or maybe more? It will be for vegies, this year; tomatoes, peppers, squish, zucchini, some type of melon, string beans, basil and that new sugar plant that I can think of. She also did beats & carrots but they did not come up.
I have a JD 445 with 3PH (Ruegg cat 1) w/2” receiver, no rear PTO, rear wheel weights and stock factory tires. I do have a front quick hitch & 4 way plow.
Any way the question(s), if going with a 20’x50’ garden, some of it new, what would you get for implements?
Thinking a Sub soiler, Middle buster and a tossup of tow behind disc harrow, can’t find 3ph type & under $500 or a walk behind tiller, again can’t find a 3ph self powered one for less than$1200. I will keep checking CL & eBay for local used of both types of tillers and disc harrow.
What would you not get or get in place of or used with any of the above. I.e.: get sub soiler and tiller and forget the rest. OR forget everything and just a tiller for the tractor because once the ground is broken the first time with the tiller (the hard part) the tiller will be the tool used from then on.
Thanks
Dave ----
ps: soil here is sandy but breaking that garden area where the best grass is was not fun. If grass grows then garden should was my thinking?
Thanks
Dave ----
