1 - 3 of 3 Posts
20,000 +posts!
Probably just used a centrifical clutch to a sprocket on the rear axle,instead of using the rubber disc drive wheel setup it had originally,to make a go-cart out of it....
I think thats the dipstick tube of the engine (attached) almost resting on the frame of the rider. So that would look to be a vertical shaft engine turned 90 degrees on its side and hopefully resting there. Otherwise I'm not sure the oil splasher would properly lubricate the critical internals of the engine.
1 - 3 of 3 Posts
