Mike,
For the BX, 1400 rpm is slow Idle and is normal. For us BX owners, fast idle means just crack the throttle open some so the engine is not running at its slowest speed.
Big trucks have a fast idle button that they push/pull to make the engine idle faster. That's where the "fast idle" term came from.
Idling a diesel for a long time is bad for it in theory. So its better to run it at fast idle than slow idle. I'm not sure all the exact reasons slow idle is bad, but I think its a combination of multiple things. The engine doesn't run smooth at slow idle, the fuel mix firing in the cylinder when the piston is moving slow puts more stress on the crank, and piston connecting rod, there's more carbon build up because its not running hot enough to burn clean.
So I never let it run at 1400. Only when shutting down, I throttle all the way down then shut off. On start-up I let it warm up at 1600. When I'm working and need to stop working to get off the tractor to do something, I let it run at 1500-1600, for few minutes. If I need to take a longer break, I shut it off.
