What size flail mower for a 2305?
3697 Views 9 Replies 5 Participants Last post by  Team_Green
What size flail mower would you recommend for a jd 2305 tractor? It would be used for light/medium brush cutting.
1 - 10 of 10 Posts
tank171, Welcome to MTF! I did not see where a flail mower was available for the 2305. I would check with your dealer to see if a lighter duty flail mower would work. I have an implement brouchure at home and I will check to see but in the build your own section of the John Deere website, flail mowers are not listed as an attachment available for the 2305.:goodl:
tank,
I don't know of a flail mower for the 2305. It's possible there is an aftermarket one out there, but the ones I've seen require lots of pto hp. :)
tank,
ditto..
Listen to JDFan and TG. States in the manual cant get the implement at least from Frontier.
Why is it able to use a rotary mower and not a flail mower?
The rotary mower does not require as much PTO horsepower as the flail mower. The lightest flail mower available by Frontier requires a minimum of 30 horsepower.
I regularly use a 6ft flail with my NH TC30 (24 pto hp). The mower will completely stall my tractor if I try to go too fast and have let the grass get too high. In other words, you are not going to see me running 10mph thru near waist high grass like mower commercials show. On the other hand, if I slow up a bit, the cut looks great and no one can tell I didn't use a 50hp tractor.
There are smaller flail mowers made that could work like that for your 18 pto hp machine. Here is a pic of a 48" one I found on Ebay. There are other sizes available. If you don't have to run at high ground speeds in a big hurry, a flail could work just fine.
I would worry about blowing out my pto.. You can use a flail that should have 40 hp.. BUT is it working at the right pto speed and is your tractor over loaded.
Go talk to your dealer about it. IF he says he would not warrenty the use i would not run one.
1 - 10 of 10 Posts
