Sorry this is long...I have a few things I needs to tighten up, tweak and adjust on the FEL I installed on Saturday. But I am looking at what I should work on next. Here are the attachments and thoughts on each I got with the tractor:
1. Seeder - My son will be using the seeder so he is getting started on that one at his place.
2. Mowing Deck - My son has a riding mower already and I don't have the lawn that needs a riding mower (too much landscaping to justify a riding mower). This one will wait.
3. Front Plow - This one is interesting. As I used the FEL to clean up the piles of snow next to the driveway on Saturday I noticed the bucket did not scrape the ground very well. It is ice and packed snow, so that is understandable. The mounting for this plow is not stock and was fabbed by PO. I may need to remove the undercarriage for the FEL to put this on. I also have a JD plow that I adapted to my stock Bolens mounting bracket. I would like to build a bracket to attach my JD blade to the bucket mounts of the FEL.
4. Sickle Bar - My son might use the sickle bar a couple times a year, so that one will be his job to restore as well if he wants to use it.
5. Mortarboard Plow - I need the 3pt to attach this.
6. 3pt Hitch - I need this to attach the mortarboard plow.
Currently there is a steel box 14" x 14", 12.5" mounted where the 3 pt normally mounts. I have not weighed it, but by calculations it should be about 225 pounds. I like that weight for the FEL. I did notice when I first was playing on Saturday the tractor felt a bit tipsy with the bucket high and on a slight side angle. I can see why James has dualies.
Now that I have the FEL working I need to decide what to do next. I know come Spring I will need the Mortarboard Plow. With that the 3pt hitch. What has people done to add weight but still keep the 3pt attached. I have looked at wheel weights. This is an option but I already have the weighted box. Is there a 3pt attachment for weights? I am still looking locally for a Disc that I can use or modify to use. Once we Mortarboard Plow my son's garden plot I will need a disc to cut it finer.
Where should put my energies? I appreciate all input.
