1 - 3 of 3 Posts
So, I busted the brackets on the back of the tractor but I have no clue what they are called in order to replace them. They attach the adjustable arms to the back of the tractor by a bracket. I have a Kubota l3010. Bent the left side and completely busted off the right side.
From the rust, it was cracked long time ago and it finally gave up.
Have you tried Messicks? You can check the parts diagram on their website to find what are you exactly looking for. You can also order online I believe.
On the other hand, if you have the broken part, that can easily be welded and actually reinforced.
Professional Homeowner
Maybe lower link brackets? That’s how I would describe them to a parts retailer.
Pictures help a lot. Maybe take another one from a longer distance away or different angle with someone pointing to the parts in question. That often helps a parts counter person see a better view of the area where the part is located.
1 - 3 of 3 Posts
