1 - 20 of 39 Posts
· Senior MTF Member
I'm a Cub Cadet guy and my 3 choices are CC.But I did check other brands but the steering wheel and my great luck with the higher end cubs brings me to these three.
I have never owned a zero turn but hopefully I can get some input on these models.I mow 5 acres with some hills.
The tanks are out of production But I called around and fond some new ones out of state.
I have got the prices as low as I can so far.
The new series Pro z160 for $7200
Tank s60 $8000
Tank sz60 $9700
Thank You
· not quins. but sextuplets
may I suggest u get away from the CC zero turns.. the JD units last a lot longer & r easier to work on.. our CC dealer sent his back to where they came from last year..
· Senior MTF Member
My dealer let me use a tank last summer for a weekend greatest mowing experience i have had.John Deere is about the only brand I did not and will not consider!
The 3 models I mentioned are the only ones I'm interested in.
· Senior MTF Member
Looked at the Tank sz60 and a Pro Z 154 (I'm interested in the Pro Z 160 )Took some pictures of both.1st set the Pro z and 2nd set tank ☺
UUUUMMMM... Y the ROPS on both.. do they have a problem with tippin over..
· Senior MTF Member
Discussion Starter · #8 ·
Not sure how that helps me decide? But all the brands I have looked at have the roll bars in this class. I will not be using them anyway because of trees.the tank I demo last summer did things on my hills I would never try with my garden tractors.In fact with the front steering vs the swivel front end.No salesmen from other brands could say their machine could out do or even match them on hills.
Lots of nice higher end zero turns out there.They all use the same engines same transmission just depends on your price range. But with my hills I getting one of these.
My biggest concern besides the hills is what engine not brand of zero turn.Kawasaki FR ,Kawasaki FX,Kolher Confidant or Kolher Command. Im very confident in the transmission used in the higher end models of any brand.
when it comes to engines the Kawi's like ur pocket book.. any part for them robs u of ur cash.. give me a Kohler Command Pro..
a sterrin wheel unit is not a true 'Zero Turn' unit.. it's actually a glorified GT that can't do jobs the GT can.. for one.. make one rear tire go in reverse while the other goes forward.. when u get one to do that.. the driver does a 180 or a 360 right where he's at.. a true zreo turn saves time & effort when turnin around.. a sterrin wheel unit has to make a big loop circle or reverse to do it's turn abouts..
· Senior MTF Member
Discussion Starter · #11 ·
I agree with the command☺
But I respectfully disagree with the models I picked not being zero turns.The front wheels turn with the wheel plus you still have a separate transmission for each rear wheel.That makes it a zero turn.with the front wheels stabilized and the rear wheels both working independent in forward reverse or turning It give great control on hills.
Like I said I demo the tank last summer.my ditch is steep I have never mowed it with out doing the setting on the side of the seat so it won't tip.Didn't have too with the tank.
· Senior MTF Member
Discussion Starter · #12 ·
☺☺☺ I would like to add If it's not a zero turn thats ok.it did everything "I"wanted it to do.It went around small trees large trees buildings and flower beds.I didn't have to do the dance, I do with my beloved garden tractors.☺
I have a hill side that I mow the wrong way of the recommended way.. I use a Scotts 2048 mower.. it's made by JD the same as a L120.. only different colors.... this mower I added weights to it in the proper places to lower the center of gravity.. with it I no longer have to ride side saddle or just half on the seat.. I don't need ROPS on this machine.. the JD L120 is an oversized LT tractor.. it does have 12 inch rears but on 'slide on the axle' rims.. it will also mow fast & give a great cut..
· Farmer
Just did some of this looking around at "Z"'s and looked at Cub Cadet and Toro. I wanted a steering wheel also, my budget is a little lower, but I really like the Pro Z Cubs and the Pro 500 S series is really nice, but out of price range. The reason I am adding this is the unit that is sz60 is not the far from that pricing. Best of luck and hope this is more on track with the question that was asked. I am probably going with the Toro. Great choice you have made.
· Senior MTF Member
Discussion Starter · #18 ·
Thanks you ?
I have a 2011 Z-Foece S60 Commercial.
My vote would be the Pro Z160. Or wait for the Pro Z 500,700, to 900. It looks to me like they are stepping up to play in the commercial markets with these machines.
Now, let's talk about steering wheel zero turns. I have long said that if John Deere had developed the zero turn steering wheel they would far outsell the stick mowers. It won't surprise me that when cub starts to gain traction in the commercial market, John Deere will bring out a machine like the zero turn steering wheel. Anyone notice Toro has entered on some of their consumer machines? My acreage has 3 acres that I finish mow with lots of trees. I had a fair amount of " turfing" with my stick zero turn. The steering wheel machine has all but eliminated that. I have a friend with a John Deere 997. Nice machine and 3x the price of my Cub. He is very fussy about how straight he mows. He talks about the challenges of doing that with the stick machines. I just hold the steering wheel straight and cut a straight pass. My wife mows with it, as well as my 10'year old once in a while. Not hard to get the hang of. I doubt my buddy is going to put his 11 year old on that 997 for a while.
Now, let's talk about engines. Mine has a Kohler Command Pro. When it was new, it ticked. Dealer said it was valves, others have said it is lifters. Every so often it still does it. Nobody seems too worried. My previous mower had a Kawi. Never had any trouble with that engine. My point is this-I think engine mgrs make good and bad engines. Can anyone say Kohler Courage? I think Cub is picking higher end engines from both Kohler and Kawi in these new mowers, so would feel confident in either.
I mow my ditch bank. I acquired a John Deere X748 2 falls ago. I intended it to be my fall leaf clean up machine for pulling a cyclone rake. I also thought it could be my ditch bank mower because of the 4x4. The Cub has a lower center of gravity. I have tried the John Deere multiple times and I have always found it better to do with the Cub. It amazes me how it hugs the ditch bank and climbs back out of the ditch.
Last spring I took my mower back to my dealer for a look over and to get it ready for mowing season. He told me they lubed some linkages, made some adjustments and looked everything over and she was ready to go. This was the first time I had taken it back since new. I wouldn't say I thought there was anything wrong with it before they looked at it. I really felt like they brought it back to new. I can't pinpoint it exactly, but it really worked well last summer. My dealer is my hometown dealer, not my local. They sell over 200 new units per year and you can tell. When you get within 10 miles of their dealership, it seems like every place you pass by is running Cub. This is farm country in Iowa. John Deere's strength has a lot to do with their parts and service. They break and the local dealer can have you up and running the next day because they can get parts quickly. Pick a solid dealership that knows what they are doing.
Good luck in your decision.
1 - 20 of 39 Posts
