Only the HT-23 has it in the large frames. I believe the Duratrax/GTX models do too. These all have Eaton 11 transmissions.
I'm not so sure about the G10 I have a G10, that by it's model/serial number (Mod: 1055 Sn#: 0400929) is a 1977, and it doesn't have the 2-speed rear, nor does it have the controlled differential....Tube frames with "real" 2-speed rears are as follows: 1000, 1050, 1220, 1053, 1253, 1054, 1254, G-10 (1977 on (1055-04)), G-12, G-14. I hope I haven't missed any.
Good luck in your quest.
hmm? famous rears for sure, but i'm not sure how they are considered 2-speed?Beyonce, Shakira, J-Lo (sorta) . . .
Well, it may STILL be correct. Bolens1000, who is something of a "Tube Frame Guru", says that he has seen G10s with the 2-speed and controlled differential.You are a wise man, OldBuzzard; I did get that info from the Sonny's Bolens site. So, the info regarding the 1977 G-10 (1055-04) having a lever-actuated hi-lo range may indeed be incorrect. Sorry for any confusion I may have caused.
We would love to see pics of that set up.i have a 1968 1250-has a 2 speed rear in it,didnt think anything about it until i purchased a 1969 1250, noticed transmission lever on 69 would put tractor in neutral-drive and park,on 68,-it was high- neutral and low,previous owner must have done the swap,i really love the way this tractor performs, not complaining at all,yet i sure would like to know what this rear is originally out of,anyone know how i can identify,sure would appreciate any guidance. -thanks- kyle:
I think it's possible, but I've never seen it done. They are both more or less the same size axle, and it probably wouldn't take too much to make the HT23 rear work. It sure would be a nice swap for a tractor with a tired eaton 12.Can you even take the rear from an HT23 and put it into a 1250 without major modifications?
