I want to make an adapter plate with a "J" slot so I can allow my Powered Sleeve Hitch to Float.
How long should I make the Float Slot?
The Actuator has a 4" stroke.
The Sleeve Hitch is a Sears/Husqvarna.
The idea of a "J" shaped slot is so I can gain Ground Clearance easily for transport.
If the "J" slot is a bad idea, you won't hurt my feelings.
Something like this rough sketch, but I will place the Attachment Hole more central to retain strength and trim the bottom too.
Yesterday I used the Blade on a 100' long Gravel Driveway. It went well except where it transitions to concrete.
At one end there is a small abrupt drop and the other a rise.
There I tried to be careful and feather the blade.
I had to make quite a few passes to bring the Gravel to the top.
When I was done I walked up and down the drive, thinking it looked pretty good and I was happy with the results.
Unfortunately, last night when drove my Miata, with a Very sensitive Suspension, onto it I was quickly aware of the washboard I created.
Last year soon after buying my GT I bought an Agri-Fab Box Blade to level an area around a Septic Line/Clean-out installation.
The crew left that area on the lawn bare and in pretty rough shape.
The grass/weeds that started growing became a torturous bronco ride to mow.
After the experience of leveling that out, I decided that I wanted a Powered Lift and the capability of applying down force.
Later, on a small job, I realized the need for the blade to float, but never gave it a thought after that.
Now I want to do something about it.
Thank for your thought on this.
Rich
Rich
