1 - 7 of 7 Posts
Hi its the brake drum look between the rear wheel and the final drive you should find where it goes
Thanks. There is a piece on each rear wheel that looks similar to that part. Since each wheel has one, I still don't know where is belongs. The surface is polished from something be run on it. What is your second guess?
Better check again it fits inside the brake housing there is no 2nd guess its the brake drum that's why its shinny / polished here is a picture of my 49 with brake assy its a little different but has the same components
This picturs show the brake assembly better you can see the drum and the brake housing
Vehicle Construction equipment Crane Outdoor power equipment Machine
Thank you very much. I was not able to see where anything was missing. I downloaded a manual and see where it should be. Thanks again for your reply.
1 - 7 of 7 Posts
