:ditto:It's the same Onan CCKA 16.5hp as used on the 816. I think Gravely just upped the model number to 817 for the last year, before switching over to the 8000 series. They added the seat riser but dropped the rear liftable hitch and rear PTO. jason
I've only seen 3 or 4 817s in person and they've all had CCKA engines. That's the reason it's an 817 - it has the 16.5 hp CCKA. Otherwise, the 16hp B43 gives you a model number of 816T. The '89 customer service update also lists the 817 as only having a CCKA, for what it's worth. I think it's correct in this case, though.It could also be a B43, and I would find that to be more likely. Most 816Ts have B43s.
Correct and I believe I have a 1978 brochure with the 816S, 816T, and 818 all sold concurrently. In 1978 the 8000s came out too. A lot going on that year.Hmm. So Gravely was making the 817 and 816T at the same time using 2 different engines? That seems totally redundant, but it doesn't surprise me.
You don't happen to have a scan of that, do you? I'd be interested to see how Gravely's marketing department dealt with that.Correct and I believe I have a 1978 brochure with the 816S, 816T, and 818 all sold concurrently. In 1978 the 8000s came out too. A lot going on that year.
I don't have a scan yet but I have been going through them slowly. I am about halfway to my goal of collecting all the full-line brochures between 1968 and 1987.You don't happen to have a scan of that, do you? I'd be interested to see how Gravely's marketing department dealt with that.
