What in the world happened to my steering?
1073 Views 6 Replies 6 Participants Last post by  LLigetfa
I don't have time to tear into it tonight... but I parked my GT steering fine a couple of days ago... went to move it last night and it took all I could do to steer it, and I am not a lightweight.
I looked for the obvious, anything stopping the steering wheel gear from meshing with the pitman arm (or what ever it might be called on a tractor).
No obvious blockages.
I will:
Jack it up.
Disconnect the steering connector arm and see if it's the wheels/front end causing the problem...
But has anyone had this happen?
I've been meaning to grease the front end but I don't have a grease gun that will fit it... I keep forgetting to pick one up.
Could it be something that simple that quickly???
There doesn't seem to be any visible breakage anywhere.
1 - 7 of 7 Posts
Maybe a mouse made a nest in your steering gear.
check for a tire that is low on air.
Did it get rained on? My Cub Cadet steering would get seized if I left it out.
I had locked up spindles on my MTD, but it had sat in the woods for several years before I rescued it. Greasing solved the problem, but I am going to replace the bushings anyway.
I'd definitely check for a mouse nest as LLigetfa said. Little buggers are quick, and a serious nuisance around here.
Last Winter when I took out my snow thrower, I noticed that the gear selector wasn't as smooth as I remembered it to be but thought maybe my memory was flawed. To make a long story short, I eventually sheared a bolt on a drive sprocket and when I took it apart, there was a huge amount of mouse nesting material wrapped up around the shafts and sprockets. It was a wonder that it moved at all as most of the horsepower couldn't make it to the wheels.
1 - 7 of 7 Posts
