OK,
For the Transmission ( K71B )
My owner's manual says J20D
My Tech manual says J20C if used above 32F
I called two local Deere dealerships and one said J20D and the other said J20C.
I emailed tuff torq, they say J20C but had no comment about temps when I asked about what the tech manual said.
I plan on using the tractor for pushing snow this winter so I am concerned the tech manual says J20C is only appropriate above 32 F. It will be colder than that here this winter, but will also be above 100 F next summer.
I would like to stick with the JD recommended fluid, but if I have to go to an engine oil (5W-30 or 10W30 as advised in the tech manual) I will.
Please advise. I really want to get this right the first time. :praying:
I am also planning on changing the engine oil to a full synthetic at the same time. The owner's manual suggests 10W30 or 10W40. Tech manual says 5W30 or 10W30. Any suggestions there?
Should I just get a couple gallons of 5W-30 and use it for everything??
I have read way too many posts and tried to figure out why the owner's manual and tech manual don't agree. I am just confused! :banghead3
Just Use the J20D which is Low Viscosity HY-GARD You can use it Year round
Directly from Deere Manual
These machines are equipped with an internal wet disc brake transmission. Use only Low Viscosity HY-GARD® (J20D) transmission oil. Do not use type "F" automatic transmission fluid.
John Deere Low Viscosity HY-GARD® (J20D) transmission oil is specially formulated to provide maximum protection against mechanical wear, corrosion, and foaming. It may be used in all operating temperatures.
I Use JD Low Vis Hy-Gard Year round has a Maroon Label :thThumbsU
Thanks for that Sergeant. I was ready to go with J20D but when tuff torq and my tech manual said different it made me second guess myself.
As always, this site is an excellent resource!
Just make sure you get the Low Vis HY Gard there is regular HY Guard has a Purple Label:thThumbsU
