I remember it being said that these couplings are rare birds. I don't have any ideas of where to find one except on another blower, Richard's, etc. Might using a higher grade of bolt be better than a roll pin?
Maybe. The good news about a roll pin is that it expands to fill the hole, so no chafing. But a bolt might be overall stronger.Might using a higher grade of bolt be better than a roll pin?
SorryNeed to make a plan......
Check your axle brackets. If they're even slightly skewed, that will produce a noticable height difference in the ends of the blade. Also check your rear tire pressures. Same thing.I also noticed my plow has a tilt to it.
Good points and I’ll make sure the brackets are straight and the tires are the same.Check your axle brackets. If they're even slightly skewed, that will produce a noticable height difference in the ends of the blade. Also check your rear tire pressures. Same thing.
How 'bout some pix of your freshly rebuilt machine?
And +1 on the fun![]()
+1you need to be more deliberate when going across the "H" with the shifter so that the recesses in the gates underneath the shifter plate line up side to side.
Your setup looks like it just came off the showroom floor. Especially the blower. That chute doesn't appear to have ever seen and sand or gravel through it. Neck even on blacktop I have to repaint mine every few years. Mainly because of the area along the road from the town sand trucks and their very course sand. Good for traction on the roadway - not so good on the blower going through the banks they leave behind.8" overnight on top of the 12"+ that we've gotten over the last week. Ran out of places to push the snow so out came the blower.
