Is that real, or PhotoShop???
Real attachment you can buy. Harbor Freight even sells one.
"Sawstop" is the hotdog demo. Newer circular saws have a brake, but older do not. Not gonna lie...used my thumb on the side of the blade many a time to slow the blade to a stop much quicker on an older circular saw. I am sure you know someone else that has done the same. Kickbacks and binds are an issue, but I think the most common danger I've witnessed is setting the saw back down with the gaurd not kicked back into place either from a worn return spring or debris holding it back. Seen someone forget they pried the gaurd back open with a carpenters pencil (rectangle ones) adjusting a cut that went to a fine point and set the saw down. Then there is also holding a board and not realizing where your fingers are underneath. And don't use your knee as a sawhorse. Sounds dumb, but people learn the hard way all the time....that would stop the blade if something soft (like your finger, they demonstrated using a hot dog) hit the blade (do they still sell these?). Do circular saws have anything sort of brake?
Yeah, I watched a video outlining a bunch of that stuff, including holding the wood with your fingers under the cut path. Just reading about it makes me cringe."Sawstop" is the hotdog demo. Newer circular saws have a brake, but older do not. Not gonna lie...used my thumb on the side of the blade many a time to slow the blade to a stop much quicker on an older circular saw. I am sure you know someone else that has done the same. Kickbacks and binds are an issue, but I think the most common danger I've witnessed is setting the saw back down with the gaurd not kicked back into place either from a worn return spring or debris holding it back. Seen someone forget they pried the gaurd back open with a carpenters pencil (rectangle ones) adjusting a cut that went to a fine point and set the saw down. Then there is also holding a board and not realizing where your fingers are underneath. And don't use your knee as a sawhorse. Sounds dumb, but people learn the hard way all the time.
Only because I use car doors every day!Mikey you could take a finger off closing your car door before you lose one to a saw.![]()
