1 - 13 of 13 Posts
Ben's Lawn Mower Repair
i replaced the carb on on Yardboy Tiller (w/ briggs intek horizontal) and it ran just fine. I changed the oil, put the airfilter assembly on. I tried to start it and i think I heard something pop in the area of the recoil assembly. the recoil assembly seems to work fine but now I cannot get the machine started.
i took the air filter assembly off and tried to start it. no start but there is a puff of smoke and gas that comes out of the carb itself.
I was running perfectly, then now nothing but backpressure.
Did I just break the flywheel key? how?
Any ideas are appreciated. I will pop the flywheel today to see. wish me luck.
Certified Technician
doubtful, it wouldnt make a pop. probably just one of the pawls slipped over its notch and onto the next notch.
Check for spark, check for compression, and fuel...
Red-
Thanks. I will check for spark, compression and fuel.
I will say though that when I pull to start, one in 5 pulls will do a kickback.
I thought I was done with this beast but I'll have to spend more time sorting it out. ugh.
ben
compression >90psi
has spark- has a new plug
has fuel
- another couple of observations--
-sometimes it is hard to pull (almost like the rope will break)
-raw fuel is dripping out of the muffler!!??!!!
help!
i started taking the carb off. lo and behold, the whole intake manifold was filled to the brim with gas.
so i take the new carb off, take it apart to see if the float has a crack. all is well.
i put it back on, take the spark plug off and blow out the hole with air.
i tried to start it. no start but i see some flame coming out of the carb.
what does this mean? is this just a symptom of the flooded engine? should i just let is air out first?
or is this a sign of a flywheel key issue?
Id take the plug out, turn the ignition OFF..and pull it through a few times, blow air down the plug hole and stuff.
Then put the plug back in...leave the ignition OFF..and pull it a couple times, no choke. If it feels normal, turn the ignition on...if it kicks back, its slipped timing.
give Red a cigar!
the flywheel key was sheared.
still scratching my head as to how this happened but thanks to Red the Oracle of the forum.
Dont see many sheared keys on those engines, in fact I dont think ive ever seen one. But then id never see na sheared key on an Onan Performer series..until mine sheared for no apparent reason.
Keeper of the bees-Now deceased
I would change the oil as it probably has gas in it.
1 - 13 of 13 Posts
