:biglaugh: I hate to criticize Rol:bananapow but his choice of "fire" in his post is something that might be misinterpreted. Some of us reserve that term to describe the high voltage spark but I realize that there are differences in some regions of the continent.
If you are certain that you have the points set correctly and that you did replace the condensor and the coil with OEM parts, then you need to use a test light or a simple multi-meter with a DC scale on it to find out if you have 12 volts coming to the positive terminal on that coil with the ignition key in the "ON" position. You also need to make sure that the 12 volts is still there during the cranking cycle with the starter or the engine will not start.
The fuse must be OK because you can get the starter to spin by using the ignition switch. However, it is possible that you have a loose wire, broken wire, damaged wire, corroded wire, a wire off or a bad ignition switch that isn't allowing the 12 volts to get to the coil.
You could also just run a jumper wire from the positive battery terminal directly to the positive coil terminal and then spin the engine. If it starts up, then you know the engine is OK and so are the points, condensor and coil.
Check it out and let us know what you find.
