Mechanically inclined or not, it’s crazy that he would leave his $3k engine exposed to the elements like that.
Mechanically inclined or not, it’s crazy that he would leave his $3k engine exposed to the elements like that.I believe he wanted to repower it with a new engine. But did not want to drive to Nevada to get the engine. He is going to be getting a slightly bigger used diesel tractor with a loader on it from some one he knows. He does not seem too mechanically savy IMO but that's just my observation. He was able to get the motor in and out. So he know how to turn a wrench for the most part but I’m thinking he might not have a grasp of all the inner working of the internal combustion engine or knowledge and ability to do the research for causes of the problem. Very nice guy by the way. I’m in no way attemping to knock him and his abilities. I could not help but feel bad for him on the loss of his investment.
You might just need to clean it out and reuse it...It does not look like that valve M76125 was replaced.
I’m under the impression the rust won’t just go away and will always be there and will eventually lead to an early pre mature problem. As much as I don’t want to do a tear down, I think it is probably best. I’ll have to get a parts list together for gaskets seals, rings, piston etc before making a final decision on if I’ll get it running again w/o doing a tear down.Ah, the rest of the story. The compression differential all makes sense now - likely sticking rings in that cylinder.
You're probably headed for a teardown but you won't hurt anything by putting some hours on and seeing if it improves.
And based on the info you provided, I personally don't see a point in doing a leak-down test.
All depends on what you want out of it. Some folks are happy with good enough, it might get there with some run time, but probably not.I’m under the impression the rust won’t just go away and will always be there and will eventually lead to an early pre mature problem. As much as I don’t want to do a tear down, I think it is probably best. I’ll have to get a parts list together for gaskets seals, rings, piston etc before making a final decision on if I’ll get it running again w/o doing a tear down.
IMHO, the damage is already done. If it was sitting wet for some time, you might be looking at another overbore assuming you can get pistons in the needed size.Won’t rust cause gauling in the cylinder.
I missed that the engine had been pulled - I agree, tear it down and get it over with.What you do is up to you. However, the engine is out of the tractor right now and outside of the water in the cylinder, it should be pretty fresh. If you clean up the rust, it sounds like you have a nearly new engine.
It would suck to install the motor and find an issue later and have to pull it out to fix...
Again, the FD620 is a very easy engine to rebuild.
I think you have to have the piston at top dead center, on the compression stroke, to have both valves tightly closed. You won't have much of a test if one of the valves is open.If you are going to put compressed air into the cylinders, I'd suggest you put a regulator in the line and start near zero psi and slowly work up, listening for any air leaking from the exhaust (leaking exhaust valve) carburetor (leaking intake valve) or crankcase ventilation valve (leaking piston rings) checked at the hose #1 on the parts breakdown picture you posted. I'd put the piston at the bottom of it's stroke so the compressed air doesn't push it down there for you.
Thank you,In your video you asked about the upgraded valve covers. Yes, you can buy OEM versions of these for both left and right side. Plastic was the original cover and as you can see, didn't hold up.
