Thanks for the update.
Yeah, after messing the the head and head gaskets, the valves definitely need to be set. Since it's a 4 cylinder, yes, the 1 and 4 cylinders will be 180 apart from 2 and 3. I think your are on to something there. You set the 1 and 4 cylinders, then rotate 180 (align the mark), and set 2 and 3.
I'm kinda used to the 3 cylinder ones.
I haven't look on the timing marks on my tractor. I want to check those but every time I'm going to actually use the tractor, I just forgot. Looking at the service manual for my tractor, the marks are indeed in the same spot as yours. They are just spaced different because mine is a 3 cylinder.
Now for the white smoke. Did you power the glow plugs? If not, you need to energize the glow plugs for maybe 5 to 8 seconds. It will probably start right up. All you need is a wire coming from the positive lead to the glow plugs, hold it for 5 to 8 secs, then remove the wire and crank the engine.
With the original wiring, once you turn the key to run position, it would cycle the glow plugs, but for now you can just run a separate wire.
