1 - 12 of 12 Posts
I also got a well used 10324 yesterday, it needs a different wheel for the left side, plus pinion gear. The deck is little rusty, which i could repaint it. It did run great for a couple minutes, but coil is shot. Throttle cable feels like it is is corroded too. I think it was kept outside. I had to pressure wash the grime off of it.
I might fix some of it to sell it. When the ignition coil worked, the engine ran fine with a little surge which i can correct that with a bigger pilot jet. It also needs a good carburetor cleaning. I would take the parts that I need off of my other 10323 for this machine and get the new parts and install them on 10323.
well, its been posted in here before, can try to bake the coil..
its a tough machine in my opinion
if it were me i'd give it the tlc&keep it
Discussion Starter · #3 · (Edited)
Well i am baking the coil right now with 30 minutes to go. I did swap a good one from my very nice dura-force equipped lawnboy 10552 and whammo! it runs now. I did order 2 new coils for 20 bucks off of ebay just in case. And 2 new drive wheels for 10 bucks each.
I will probably put the new drive wheels on a 10323 mower i have, and take the used ones and put them on the 10324.
Just as expected, the old coil works with baking it at 225 degrees for one hour.
that is great news. I just got a free 10323 by the side of the road, in great shape. its just missing the spark plug and the coil from what I can tell. How hard is it to replace the coil. Do you have any pointers on how to do this. I have never done it, just curious. pics or diagrams would be really helpful!
Take out 3 screws with a #2 Philips screw driver to remove the starter/gas tank housing, put it aside (you can keep both hoses attached). Unbolt the cooling air shroud (there are 2 nuts, and 2 bolts to take off), then remove the air shroud. Then there should be 2 long skinny bolts that keeps the cdi coil on. Those take a 3/8ths socket or wrench to take off. Use those long skinny bolts to secure cdi/coil, and set it .010 '' clearance from the fly wheel. reattach everything and check for spark, then try to start it up.
If there is any thing I missed, anyone is welcome to chime in.
Thanks. I just ordered an new coil on ebay and I hope it will be here soon.
Thanks for the tips
Thanks for the tips
There's a 10323 listed on KC craigslist needing a coil for $30.00 and my sister picked one up for me from a guy in Lenexa last night. Any of those yours?
nope none of those were mine. I ended up giving my m-series and a DF to my dad. His lawn girl and new toro both threw their self propelled's out again! Those mowers are junk!
Chewy thanks for the help! The coil was really easy to replace. I just used the business card trick and it works like a charm. How is your Duraforce coming along? Got any pics?
It probably isn't worth fixing if you are going to resell. Most good to excellent condition df mowers struggled to get $150 on ebay this season and the power head would probably do $75 if you just sold it now that you got it running.
that gives me food for thought,
keep my df or sell as is or repaint then sell
i saw a real hot color that would match
them new camaros have "synergy green" paint it pops in the sun, however,
the paint aint cheap...
if i finish milling a new rocking key, its basically ready to go
1 - 12 of 12 Posts
