That's funny!
:thThumbsU:thThumbsU:thThumbsUIs that tractor named "LINUS".
It is now!Is that tractor named "LINUS".
It is an old drop spreader I modified. I drilled sheet metal screws into the solid rubber drive tire for traction and extended the handle so I could reach it with the weight tray on my Craftsman. I only use sand, mainly because I never use salt on the driveway but also because I think the rust is all that's holding the spreader together, so salt probably isn't a good idea!Does the carpet match the drapes? --Sorry, couldn't resist. :drunkie:
On a serious note, is that a drop spreader you use? have you used it with salt?
