1 - 3 of 3 Posts
Today the water pump on my 8N broke. The front of the casting along with the impeller broke. After I removed the pump I found that some of the pieces of the impeller fell into the engine block. Will this create any problems or will they sit in the bottom of the block. Here's a picture of the remaining impeller.
No problems. Try to fish out what you can with a magnet or take out the thermostat and back flush the block with a garden hose to try and push them out with the water stream.
Sent from my SM-N960U using Tapatalk
As Racer_X said, there "should be" no problems. If you can flush it out would be better. The piece(s) will be in the cooling system and the only moving parts in that system are the water pump and the thermostat. When you get her back together, watch the temperature. If the chunks are big enough they could plug the cooling system or they could move to stick in the thermostat or water pump causing problems. Good luck.
1 - 3 of 3 Posts
