1 - 7 of 7 Posts
My rims on my dodge truck are aluminum, the clear coat on them from the factory is nasty after all the miles i have put on the truck. I am thinking of sand blasting them Then painting them black with hi temp paint.
What do you guys think? Could i possibly ruin the rims? Would hi heat paint stick to aluminum thats been blasted???
Used to be a shop in Edmonchuk that refinished aluminum rims. If they're still in business, they might supply guidance.
Team Green,
I wonder if epoxy prime, after sandblasting, followed by a top coat of paint would hold up on aluminum ??
Inferior or cheaper primers don't like to stick on alum, because it is always trying to oxidize.
Beaumont { :>)) www.petperfectexpress.com
Golden Rule - "he who has the gold, makes the rule"
http://www.mytractorforum.com/showthread.php?t=135888 http://www.mytractorforum.com/showthread.php?t=136600&page=3
1992 JD 318 original paint w/484 hr. on P218g Onan & #49 snow blower / 1998 JD GT262 w/brand new Kawasaki OHV & 48" rebuilt deck
http://www.mytractorforum.com/showthread.php?t=135838
I had to use a special primer when I painted my aluminum flat boat years ago. Can't remember the name of it but it wasn't hard to find. I was told then that aluminum wouldn't hold paint too well without this primer. Ask someone in the boat bidness and they'll know what i'm talkin about. good luck.
use Zink Chromate primer , the aircraft type , yellow green in color, follow by a 2 part epoxy primer filler , then top coat.
Hmm This is sounding mighty spendy to this cheap bugger.. Thanks for the info guys.. I'll look up the edmonpuke guy for advice..
1 - 7 of 7 Posts
