Well, we have a member here Ellis his screen name is "Tiretrx" and he has a 24G. I am sure he will be along shortly and maybe he can provide a pic.
- Kris :rauch10:
- Kris :rauch10:
thanks, it DOES help ... helps me WANT ONE OF THOSE TRACTORS!Hope this research helps others as well. Thanks for your help.
John
To quote Ralph Kramden " Ohhhhhh, it can core a apple".The 24g must be a real beast. Ed
I found some information on the G series riders on www.oldgravleys.net. Based on what I'm reading it looks as though the 24-G is the only G series rider that was available with the 72" deck. A 60" deck was available on the 16-G, 18-G, and 20-G.Great find Bill. Thanks. If I were not so far from that offering party, I'd offer to trade my well-functioning 12-G with 50" deck in a heart beat and then repair his for my own use.
Ok, Tiretrx, would you do the following two things for us?
First use a tape to measure your deck's actual CUTTING WIDTH, not the deck plus ejector width. Confirm that yours is actually a 72" cutter.
Next, examine the photos I posted and those in the Craigslist link. Then position you camera's distance and angle either from front to back or back to front as closely similar to one of those photos as you can so we can compare them. A 72" deck should project out 6" wider on each side than a 60" deck. All these photographed decks appear HUGE compared to my 50" deck. That extra 6" per side should be pretty obvious if camera angle and position are similar.
I've been using http://www.tinypic.com/, with photos sized close to one of these pixel size limits : 1024 horizontal, 768 vertical. Then, BEFORE uploading, I click on the bottom box which allows selecting preferred image size where I select 1024 x 768. After uploading, I copy and paste the discussion group image format address that site generates and post it into the note. Yoke, sugar, easy. Why post a tiny image when a more screen-filling image shows so much more detail?
John
Good call Bill and MY thanks! Your right, the 24-G is unique in the Pro G series in a number of ways as well illustrated in the reference material you linked. The dual drum brakes and power steering really kick *** in my book. It's interesting to note that many people consider the GMT 9000 the apex of Gravely riders, but a lot of pretty hardcore Gravely folks say it's the 24-G. I've never had the pleasure of being on a 9000 so I don't know enough to say. But I do know I wouldn't trade for my own reasons. Any opinions out there?I found some information on the G series riders on www.oldgravleys.net. Based on what I'm reading it looks as though the 24-G is the only G series rider that was available with the 72" deck. A 60" deck was available on the 16-G, 18-G, and 20-G.
Something else I noticed, the 24-G is physically larger than the 18-G and 20-G, which are larger than the 14-G and 16-G. My point is, since the 24-G is physically larger (3.2 inches wider, 8.2 inches longer) than a 20-G it would be difficult to compare tractors and decks using seperate photos.
The photos do show nice detail, especially when you zoom in.
http://www.oldgravelys.net/pdf/ProG_Power_Units.pdf
http://www.oldgravelys.net/pdf/Pro_24G_Flyer.pdf
Bill
I could be wrong & certainly haven't seen all versions of them, but it looks like a 60" deck to me. All the 72" decks I've seen have a round/radiused curve at front left corner, conversely all the 60" decks I've seen have a nearly square/sharp angular corner, as is clearly seen in your photo. The guide wheel adjustment brackets I've seen on 72" decks are located well away from the left edge, attributable to the extra (~6"/side) width, whereas the bracket on a 60" is adjacent to the edge, as is clearly seen in your photo. This bracket is also relatively long on a 72" whereas the 60" in your photo looks just like the short 1 on my 60" deck.Now that I know what how to spot the G-series 72-inch deck, they will be easy to spot.
Here are some shots of a 16-G with the 72" deck.
In regard to: "the 18-G and 20-G, which are larger than the 14-G and 16-G" I believe you'll find the only reason for the slightly different width specs was GRAVELY's choice of different tire sizes. The 14-G & 16-G came w/23x8.50-12 whereas the 18-G & 20-G had 23x10.50-12 tires. IMHO, outside of motors, there is nothing "physically larger" about 18 & 20-G tractors themselves.Based on what I'm reading it looks as though the 24-G is the only G series rider that was available with the 72" deck. A 60" deck was available on the 16-G, 18-G, and 20-G.
Thanks for clearing that up for us.The 24-G frame is longer & the extra length is easily seen as the 'stretch' between the footstand & the welded to frame deck latch. This additional length is required to fit the 72" deck's longer front to back size. The 24-G's extra width is accomplished by extending the axles & 26x12 tires.
Couldn't agree more John. At the end of the day we're here because we're interested in communicating about Gravely's. I learn every day. In my opinion the Gravely forum just keeps getting better. It's good to hear honest opinions and see questions asked and answered. Thanks for the input.This has definitely been a 2-way information flow which can help others better understand these issues and from which I learned. Yet nobody attacked anybody. Nicely done.
John
