1 - 7 of 7 Posts
I am in desperate need of help. I have acquired a 3910 Ford tractor with Auburn trencher. I want to remove the trencher and install 3 point hitch. My local tractor dealership is giving me the run around. Can you tell me where I can get documentation for the trencher? I have a tractor manual on order but the trencher manual is not as easy to find. I am a shade tree mechanic and this is my newest project any help would be appreciated
No help from craiglist guy...........I can't even find the original manufacturer anymore apparently bought out.
post some pics of the rear... has some of the rear center portion of the tractor been removed / replaced in order to mount the trencher? if so.. a salvage rear may be the easiest way to do the swap.. or at least the lift cover. etc..
post some pics and let s take a looksee.
soundguy
tried to attach pictures. Site says they are too big to upload? I will try to change camera settings and send tomorrow.
forget the camera settings.. you will likely not find a setting that will make pics small enough in size, since most camera's made inthe last 5ys are 3+ megapixel.. which can be 600-800k in size.. and ones from a couple years ago ar 5 megapixel, yeilding pic size of 1 meg on average.. , just resize the pics instead.
if you are using winxp or better you can use microsofts powertoys pic resizer.. just right click and resize. if you don't have it..it's a free download from microsoft and takes about 10 seconds to install.
soundguy
1 - 7 of 7 Posts
