Just a thought,
If I had to repower my 16G, I would put a new Kohler Command Pro EFI on it so I could retain the rear PTO belt drive - I have a bagger/vac on my tractor I would not want to give up.
It is my understanding that few if any other brands are compatable in that regard.
I know Honda makes great engines, but my one Honda experiance was not good - a pressure washer that never did run right. replaced it with a Briggs powered Troy built, its been running great for years now - never touched it yet.
Sheldon
I had my first problem with a Honda today. :banghead3
It would not start :crybaby:
Had gas Had spark would not start on ether.:crybaby:
It has a fuel shut off valve on so it had 12 volts power on it.
Then I pulled out the plug and sure both plugs where bad at the same time.
I put 2 new plugs in runs like new???????????:thThumbsU
also had a problem with a spray washer a few years a go and it would almost stop running some times.
put in a new plug and it still runs like a top.
If Honda don't start the 1st or second pull then there is some thing big wrong.
On 13 Hp I shut the gas off and let it run out and die.
when ready to run again ,open the shut off valve and choke all the way close .
1 pull most all the time maybe 2 times '
But today it was on a 24 hp and both plugs would not fire.
I may have flooded them.:banghead3
Even with that,
I much ,MUCH rather have My Honda 24 then the Kohler 19
series ll
I had for 25 years always burned oil from day one until it got so bad I had to replaced it.
