Status
Not open for further replies.
1 - 20 of 5453 Posts
Citizen of Earth
This is slightly out of date, but still a very useable list of mower parts dealers selling used, new-old-stock, reproduction and salvaged parts for older mowers:
http://jnem3.home.att.net/
Re: Sources for old mower parts
does anyone have a spring for the blade brake clutch for a john deere sb14. the spring fits under the silver deck and j.d. says it is no longer available.
Re: Walkbehind For Sale and Wanted
I'm looking for a longer upper handle from a 10323, and possibly the matching cable. Handle part number is: 100-2888-05 Thanks!
Hey guys:
Hope all is well? Lots of snow on the ground here!!!
I am looking for the following for a lawnboy:
Below are the pictures of what I am looking for:
Pull cord holder - whatever it is called!!
Throttle cable - Picture of the ends
Finally a picture of the lawnboy...
Disclaimer.. I did not paint it BROWN!! it was painted by the previous owner.
I will remove the paint prior to selling it!!!
Got the mower for FREE, had a bad coil, I found one on one of my parts engines, it runs great!!!.. it came with the bag and cover..
I want sell this mower come the spring..
Thanks
The Sea of Green Machines
Looks like that one just sneaked down to Florida for the winter and got itself a coppertone tan.. :)
Is that a V engine or a Duraforce?
I think my mind is snow blinded!!!! It's a lawnboy silver series has a 4.5hp Tecumseh 4 cycle engine on it...
Thanks
I got a 8400 commercial and a few other f engines all run and are selfpropeled
Anyone have (1) 10515 SP gears that goes to the wheel? Its #12 in the diagram below. PM me I need one that's not twisted.
No has any of what i need??
Would love to buy from here instead of ebay..
Thanks
Hey guys:
Thanks
Im sorry Paul, all I have is 2 stroke stuffs..
GTP I cant see your pic as posted. I have quite a few SP items for the gold series that I would be glad to try to get to you.
What's the chances of making a throttle cable? Reuse the cable housing, just replace the wire?
I thought about that!! got tons of throttle cables too!!!
Just straighten one end out, slip it thru and bend it back...
yes it's the one bolt type holder. Thinking of drilling a hole in the handle and using the standard metal holder.. got tons of those too!!!
If anyone has what i need just pm me..
Thanks
good yankee ingenuity there,
i heated up the starter spring on my mower,rebent it , still holding strong
Administrator
8310
Have an 8310 for sale. Here is a link with some good pictures. Old Thread.
Here are a couple new shots. Old pics are better. This is in the back of my shed right now, and didn't want to pull 2 John Deeres and a couple of others things out of the way.
Administrator
8481
Here's an 8481 that I'd like to sell. Fairly good shape. One of the machine port plugs had fallen out and it ingested some nasty twigs, etc. Piston was shot but cylinder cleaned up pretty good. New piston and rings. I've run it about 1/2 hour since putting the piston in. Still needs some carb adjustment. This has the 5 speed trans, but you have to move washers to adjust the gears.
Yellow dot on the shroud is a sticker from the garage sale where I bought the mower. It's not a primer or hole in the shroud.
Chris Schick
Still looking for a 1968 model 8227E lawnboy or a 1969 Model 8228E these are electric start mowers with the self propelled feature. I will look at all mowers and all conditions Let me know what you have. Thanks
Status
