Howdy all,
I'm brand new to baling so this is all new to me. I'm running into a rather substantially anoying problem with this baler. twic yesterday and now 3 times in 3 bales today the area where the teeth feed back the windrow into the roller is becoming jammed up with hay. I mean it is STUCK in there, which means I am on my back under this thing pulling out what looks like at least 2 square bales full of hay from the area at the roller. I had to open the back hatch and use a tool (a long one...) to yank the hay from the back side as well. Other than the jamming it seems to be working flawelessly. I am short 10 (really 20) teeth so I'm running up to get those today. The gap between the teeth and the top is 2" (which is the max I believe). The problem is right when I start up a windrow or when I try to bale in too sharp of a turn (which I quit doing!). The hay itself is pretty normal pasture mix but its pretty mature as it has rained 8 weeks straight before this first cut. Any advice appreciated. Headed out to clear the last jam and then off to Morgantown for parts.
Dr.Phil - whose arms are currently quite tired.
:bonk:
:bonk:
