Welcome to the forum. If it runs for a short time then you are most of the way there to getting it running well.
Sounds like a fuel feed issue. Start with the gas tank and make sure it is clean inside. Water or other material may have gotten in while setting. The fuel hose from the tank to the engine may need attention. Remove the hose from the pulse fuel pump and put the end lower than the tank to check for flow through the filter. The hose may have collapsed internally somewhere or started to break down. I would replace the fuel hose anyway to eliminate any future issues.
The fuel pump is next. The vacuum hose may be leaking, check for cracks. You may have to clean the carb bowl again. Check carb needle valve and bowl float. The float may be leaking and need replacement.
Your engine manuals can be DL here.
Find Your Briggs & Stratton Manual: Small Engines
