V-belt guide wire
684 Views 5 Replies 4 Participants Last post by  Everlandfarm
I need to fab up a special belt guide but don't know where to get the thick, stiff, wire. I've checked the local hardware, Lowe's and a junk yard. Appreciate any ideas or what it's called so I can do a search.
Thanks for your time,
Ev
1 - 6 of 6 Posts
1/8 or 3/16 cold rolled steel rod.
An eye bolt can be bent & modified to the shape you need..
Went through the eyebolts at the local hardware today. Decided on one that's attached at both sides, in larger sizes they're called lifting eyes I believe? This one has a 1/4" bolt, plan on cutting off the end of the eye resulting in a "Y" to hold the belt.
Thanks again,
1 - 6 of 6 Posts
