Two common areas can result in loose feeling ... First is mounting frame loose to the tractor and second is push blade loose to the mounting frame.
First, at the mule drive to frame mounts, either the slots in the mount can be worn, or the pins on the tractor frame.
Second, the main side to side pivot hole on the blade mount may be elongated, such that the blade can seem quite loose/bounce side to side, even though the angle pin is secure in the frame holes.
Brian
Brian
