Senior MTF Poster
Quit and closing out remaining used parts for 28 series L head, 28 series OHV, 42 series opposed vertical shaft engine, 44 series OHV Heads, block & more, crankshafts for 42, 44, & 28 series, carbs., manifolds, rods for 42 series, pistons for 28 & 42 series, starters, flywheels, cooling fans and much more. Including Kohler CV14s parts engine.
Walt Conner
wconner5 at frontier dot com (put in proper format)
Robinson, IL
Walt, The junk Kohler CV14 does it have an intact speed control bracket assembly and governor spring ? If so, could I buy it? thank you, Andy
Senior MTF Poster
I don't know, I would think so but haven't looked at it for a year or so, I'll try to check tomorrow, keep in mind shipping is horrible.
Walt Conner
Walt, I'm taking a guess that the CV14 speed control bracket assembly and governor spring is close enough to the mangled and springless mess I have. for the CV491 The engines are covered in the same KP 2339-D service manual Mine used a T 27 torx bit for the bracket and? maybe a T20 for the cable clamp. I'm in new territory with Kohlers. In typical fashion , I'm learning by breaking stuff Thanks for the prompt reply. Andy :D
Senior MTF Poster
"Thanks for the prompt reply"
Well sorry Andy, I got involved in a project and forgot to check as I said I would do. Have to leave early in the morning but will try to check as soon as I can. In the mean time, you might email me a test post so I will have your email and can send you a picture IF I do appear to have what you want. Put in proper format as I do not post email address because of "crawlers" harvesting addresses.
Walt Conner
